Recommended Wireless Phones - 802.11g/n
Discussion in '3CX Phone System - General' started by Sheps, Aug 16, 2012.
  1. Sheps
    Jun 14, 2012
    12
    Does anyone have any recommendations for wireless phones for use with the 3CX system?
    I know some phones are a royal pain to configure and some are fairly nice. Phones which support intercom functionality would be a bonus. Recommendations would be appreciated.
    DECT is not an option, only looking for wireless G recommendations.
    Thanks,
    Dan
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    I know of one installation that uses the Quick Phone brand of WI-fi phones. It was a nightmare at first and required some firmware updates from the manufacturer specifcally related to the MWI. I was asked to come in and consult and after finding out the application (for a residential resort condo) I had some real reservations. I know that it ultimately was made to function, but I cannot say how well. Range was somewhat limited, no real security to prevent users from changing settings, and handoff between access points was spotty. I just could not imagine having short-term guest come in and intutively using the phone without any issues and not altering the settings.
    I do not know your application, how many phones, how many access points, etc. so, I can't really provide a recommendation and probably would not anyway. All I can say, is that this make/model was able to function and I assume if Wi-Fi coverage is excellent and roaming between access points is either minimal or non-existent, then maybe it wil do you well.
