"Record" Audio -> Upload to Remote Server
Discussion in 'Call Flow Designer' started by dlo__, Nov 2, 2017.
  1. dlo__
    Jul 5, 2017
    actually I have the standard edition and I want to buy the pro edition because of the new call flow designer.
    I want to integrate a feature in my incoming call flow with an option to record audio and send it automatically to an remote server (for example per FTP).
    In the docs I have found same scenario for send audio via email (https://www.3cx.com/docs/cfd-emails-voice-app/).
    I want it via FTP or something like that.
    How is it possible?
    Thank you very much.
    D. L.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hi D.L.
    The Record component leta you record audio and save it to a local file. Then you need to send it to the remote server. If you want to do this via FTP, then you need to create the C# code to upload the file, as there is no component to do this. You can use the Launch External Script component to call your C# code and upload the file.
    Kind regards.
    Ernesto.
