Record button.
Discussion in 'CRM / Helpdesk / App Integration' started by BesOn, Jan 21, 2016.
  1. BesOn
    Jan 21, 2016
    17
    Hello. Working on call center project with 3CX VAD. There must be a function when a customer want to leave message. Offer or complain. Checked topics here where problem with record function appeared. Did not helped for me. Please help. What am I doing wrong :(
    File Name: 'C:\\ProgramData\\3CX\\Instance1\\Data\\Http\\Interface\\ivr\\DataFolder\\1.wav'
    I attached a screen.
    BR, BesOn.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,602
    126
    Hi there,
    Try changing the file name expression to:
    '..\\DataFolder\\1.wav'
    Also, change the Save to file expression to:
    true
    (without quotes).
    If you still have problems, please explain it in detail, and check the following troubleshooting guide in order to try to understand where the problem is:
    http://www.3cx.com/blog/docs/troubleshooting-vad-applications/
    Kind regards.
  3. BesOn
    Jan 21, 2016
    17
    Ok. I will try and give you a reply about it.
  4. BesOn
    Jan 21, 2016
    17
    Worked for me :) Thank you very much. What about the name of files? I tried this function:
    http://www.3cx.com/blog/docs/emails-from-vad/
    CONCATENATE(‘CallFrom_’,session.ani,’.wav’)
    Wrote it like this:
    CONCATENATE(‘..\\DataFolder\\','CallFrom_',’.wav’)
    I want the record function to save .wav file with the name of caller. For instance CallerNumber_Date.wav, Like 3CX program it does.
  5. BesOn
    Jan 21, 2016
    17
    Worked for me with this function:
    CONCATENATE('..\\DataFolder\\',session.ani,'.wav')
    If the caller number for ex 35875
    Saves file like this 35875.wav
    Maybe it will help to someone in the future
    Thanks.
