Record call button
Discussion in '3CX Phone System - General' started by PhatPanda, Sep 6, 2017.
  1. PhatPanda
    Aug 26, 2015
    58
    Is there a way to program a record call BLF button through the 3cx management console for Yealinks, without having to do it manually via the phone web interface?
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @PhatPanda,
    I'm afraid this is not possible. Call recordings are extension based, meaning that if you enable the "Record All Calls" parameter (from the extension's settings > Options Tab), all calls that are associated with that extension (internal/external), and are handled from the PBX, will be recorded.
    Using the 3CX client will give you the option to disable/pause the recording during a call.
  3. PhatPanda
    Aug 26, 2015
    58
    Got it, thanks.
