Record call's Deskphone (Yealink)
Discussion in '3CX Phone System - General' started by jjwerkman, May 19, 2016.
  1. jjwerkman
    Sep 25, 2012
    42
    In a Yealink I can setup a Record DSS key. It works. But which command do I need to sent to 3CX. So I can add this button in my BLF template. After a reprovision I need to set this key manually. Thanks.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,387
    88
    I can't remember the command in the Template, but for these kind of things you could have a look in the Yealink Admin manual to get all the BLF-related command syntax.
