Record Calls
Discussion in 'Call Flow Designer' started by oxygenit, Jun 2, 2017.
  1. oxygenit
    Oct 13, 2016
    6
    Hi there
    Where in the new CFD do we selec that we want the call to be recorded as in 3CX you select in int he queues.
    All i can see is an option to record a message and press a button to end it.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hi @oxygenit,
    You need to use the 3CX Call Control API to do that, from a Launch External Script component. The Record component only lets you record audio from the caller to a wav file.
    Kind regards.
  3. oxygenit
    Oct 13, 2016
    6
    Ok so even when i have each extension selected to record calls, it no longer records incoming calls for some reason?
  4. edossantos
    Jun 27, 2007
    1,080
    77
    Are you calling from an internal extension having the "Record all calls" option checked and the call is not being recorded?
    Can you describe in more detail your scenario?
  5. oxygenit
    Oct 13, 2016
    6
    Hi there, I found the issue. I had reached my 5GB limit of recordings. Even though I increased limit to 10, it seems to stick with the 5GB so wasn't storing new recordings.
