Record component and disconnecting call
Discussion in 'Call Flow Designer' started by pluym, Oct 12, 2017.
  1. pluym
    Apr 7, 2011
    8
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,345
    108
    Hi @pluym,
    The fix will be available as soon as 3CX v15.5 SP2 is released. This will be very soon.
    You don't need to do any change on the CFD app side, when the PBX is updated, it will change the behavior to keep the recording file.
    Kind regards.
  3. Konni
    Oct 27, 2017
    6
    Hello, is the fix in the SP2 Beta from today included ?
    I have tried, but it hasn't worked (or have I to change something in the flow ?).
  4. edossantos
    Jun 27, 2007
    1,345
    108
    Yes, it is included. No change is required on the app side.
    What have you tried so far? If you have a Record component and drop the call, the recording is not deleted. However, the "Audio recorded" branch is not executed, because the call has been droped and the flow continues in the Disconnect Handler flow. Are you trying to do something with the file in the Disconnect Handler flow or in the Main flow?
    Kind regards.
  5. Konni
    Oct 27, 2017
    6
    if I add a send mail component to the disconnect handler way, I'm getting a mail, but, it's not really that, what I wish, I have programmed a sort of order system.
    If the customer presses the one, only the specified department gets the mail, but, if the customer forgets to press the hash (or something else), and hangs up, then will the disconnect handler way executed but there I can't sort the mail to the specified department.
    I hoped, that it would works so:
    Customer pressed the 1, leaves order, press #, mail goes to department 1.
    Customer pressed the 1, leaves order, but forgets to press the #, mail with recording goes to department 1.
    Greetings
  6. edossantos
    Jun 27, 2007
    1,345
    108
    Hi @Konni,
    You just need to use a variable to store the option selected. When the user presses 1, you set the variable to 1, and then start recording. When the call is dropped and you go to the Disconnect Handler flow, you check the variable, and if it's 1, you send the email to department 1, otherwise you do something else...
    Kind regards.
