Record component + E-Mail Sender
Discussion in 'CRM / Helpdesk / App Integration' started by hpioteput, Nov 16, 2009.
  1. hpioteput
    Nov 1, 2009
    37
    Subject components works fine if user presses DTMF key or record duration > MaxTime.
    But if user hangs up the phone without DTMF - audio data from Record component is lost.
    (Record component work fine and send 'voicemail.wav' via email also (DTMF, Final Silence))
    Is it possibly to save (and send through E-mail sender) 'voicemail.wav' from Record Component if user hangs up the phone during recording?
    PS: Some peoples don't press any key after recording :(
    Thnx.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    This seems to be a bug. We'll fix it very soon.
    This should work in the following way: if the user hangs up the call, the callflow continues the execution in the disconnect handler flow. There you can put an E-mail sender component to send the recorded audio attached. But currently if the call is disconnected while executing the record component, the audio file is not saved to disk, so you can not send it in the disconnect handler.
    Thanks for reporting this. We'll inform you when we release a new version with this fix.
  3. hpioteput
    Nov 1, 2009
    37
    Can you estimate how long does it take to fix this bug?
    week, month, year?
    Really need this feature.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    We released a new version - Download it from
    http://www.3cx.com/downloads/3CXVAD2.msi
    This should concern your issue.
    Fixed: Record component was not saving the audio file properly on call hangup during recording
  5. hpioteput
    Nov 1, 2009
    37
