record component wont record to file
Discussion in 'CRM / Helpdesk / App Integration' started by jamesdawson, Feb 10, 2014.
  1. jamesdawson
    Jan 30, 2014
    21
    Hi I am trying to save a recording to file from VAD.
    I have a prompt to play when audio is recorded and a prompt after the record component has finished. both prompts play so I would expect the recording to be saved, but it is not.
    I have sent SaveToFile to true and 'true' I have set a valid path. ihave given everyone full permissions to the folder.
    what am I doing wrong?
    settings can be seen int eh attached image
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi James,
    In first place, you need to escape the back slash, because it is a special character in javascript. So instead of:
    'C:\announcement\pb.wav'
    You need to use:
    'C:\\announcement\\pb.wav'
    Also, depending on the web server used, you may not have permissions to write to a different folder than the application folder. This usually happens in IIS. If you use Abyss, it may work. So you may need to change the destination folder to be under "C:\ProgramData\3CX\Data\Http\Interface\ivr".
    Hope the information helps.
    Kind regards.
  3. jamesdawson
    Jan 30, 2014
    21
    brilliant, it was the escaping back slashes, silly me!
    thanks!
