Record personal voicemail? & office hours
Discussion in '3CX Phone System - General' started by menno, Jan 20, 2009.
  1. menno
    Jan 20, 2009
    Hello all,
    ive successfull installed 3cx on windows 2003 server and running good
    but now ive 2 problems
    i need to record my personal voicemail.. like: thank you for calling to tech department. or something like that
    where can i do it? and can i do it?
    also when i config office hours.. then when i call out of the office hours the phone is still ringing even when i setup the extension right for out of office hours.. to destination extension voicemail
    how come?
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Dial 999 to get to your voicemail, enter extension number and password then choose option 8 "Change Greeting Message"
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Have you enabled Voice Mail for the extension?
    It's on the General Tab of the Extension properties.
  4. menno
    Jan 20, 2009
    Okay but how is it possible that the phone is ringing even out of offcie and i have setup all
  5. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    You will need to review the Line Routing to see what the In-Office and Out-Of-Office settings are. Check your Office hours configuration.
    If you are using DID numbers ensure that your In and out of hour settings are as expected. It is most likely a config oversight.
