Record trunk in mp3 ** SOLVED
Discussion in '3CX Phone System - General' started by MasterX, Dec 31, 2010.
  1. MasterX
    Oct 2, 2008
    28
    hi,
    i want record all comunication of a trunk in mp3.
    can i do this?
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Re: Record trunk in mp3
    Hi, you are NOT able to do this via 3CX, however you can use a softpohne such as X-Lite which you might be able to in MP3
  3. MasterX
    Oct 2, 2008
    28
    i want record all conversation of a trunk for legal;
    for my call center i must record all ,but from administrator , not from users
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,500
    99
    The 3CXPhonesystem can record all calls from and to all extensions. That includes calls coming in from Trunks and out from trunks.
    All calls are recorded in WAV format.
    Does that work for you?
  5. MasterX
    Oct 2, 2008
    28
    ok. it's ok for me. where is this function in 3CXPhonesystem?
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Extension settings. "Other" Tab.
    tick "Record All Calls"
  7. erike4
    Nov 19, 2010
    13
    Jodix Free WMA to MP3 Converter is easily used to batch convert the wave files to MP3 if you can get your leagel team to certify the orgionality to the resultant conversion. I have a perl script to pull all the recordings, reformat the file name and then conver them and send them to archival storage. Be wary that there are some characters in the file names that do not pass the dos copy command for copying the file and must be converted which means I save both the WMA and MP3 until the leagel beagles make a decision or write policy for retention.
