Solved Record Voice Prompt WAV File Error
Discussion in '3CX Phone System - General' started by JordanLiddle, Oct 1, 2017.
  1. JordanLiddle
    Oct 1, 2017
    Hello All,
    Have a slightly odd issue on our 3CX system today, want to setup the Digital Receptionist to handle the inbound calls more effectively. Create one on 800, go to record voice prompt from my handset but the web console just gives me an WAV file error. I have attached a screenshot! Can't see anything on here with anyone with the same issue, any thoughts?
    Jordan
  2. JordanLiddle
    Oct 1, 2017
    Solved it myself!
    Turns out it's down to the actual website coding and browser. Looked at web console from iPad and it worked exactly as should!
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,365
    535
    Glad the issue is resolved and thank you for posting your solution
