Recording calls
Discussion in '3CX Phone System - General' started by jonrohan, Sep 14, 2010.
  1. jonrohan
    Sep 14, 2010
    Hi There,
    I'm looking to replace our Algo ECR system. As far as I can tell the only real feature 3CX is missing is the ability to record calls.
    Is there any way of recording internal and external calls through 3CX?
    Thanks,
    Jon
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    3cx can record calls. This is set on an extension by extension basis in the settings for the extension.
    Also if you are in a call and recording is not set on the extension you can use the assistant to record the call.
  3. jonrohan
    Sep 14, 2010
    Excellent, I must have missed that.
    I presume the call recording cannot be turned off by the user and is managed via the central console?
  4. abc123
    Nov 9, 2009
    712
    No
    The all or nothing setting for the extension is done by the admin in 3cx.
