Recording component with multiple callers
Discussion in 'CRM / Helpdesk / App Integration' started by joko, Dec 5, 2012.
  1. joko
    Dec 5, 2012
    Has someone a solution regarding the recording component with e-mail sending with multiple callers leaving a message at the same time?
    I have a simple application where a caller leaves a message if the queue time has been reached, but are there more than one at the same time only the one of the recordings get sent to e-mail.
    In log we find: 'The process cannot access the file \'C:\ProgramData\3CX\Data\Http\Interface\ivr\DS_Debug_41\record.wav\' because it is being used by another process.''
    Is it possible to set this up in a different way?
    Regards,
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    This is because you're using the same file name all the times. When you have 2 or more calls at a time, you will only be able to save the audio for one call, and the others will fail.
    To solve this, you need to use an expression to create the file name. You could use some random part, like the caller id or the date and time that the call started. You can also use an external code execution component to create a unique ID per call, which you can use for the WAV file name.
    Regards,
