recording file title - Makecall
Discussion in '3CX Phone System - General' started by petrik, Nov 29, 2011.
  1. petrik
    Sep 5, 2011
    I am recording internal lines and the files have standard format when i call directly from the phone. The name of file is [test1]_100_151_etc.wav.
    But when i call the same from api fce MakeCall or use MyPhoneClient (whitch use the MakeCall function - I suppose...) I get the name of file as [MakeCall]_MakeCall_100_etc.wav. The number of destination line lost.
    Its a error or its 'just a design' feature???
    Does it exist any setting or workaround how to repair it?
    Thans for reply
