recording messages
Discussion in '3CX Phone System - General' started by KarstenW, Sep 26, 2016.
  1. KarstenW
    Aug 9, 2016
    19
    is there a way to activate recording calls to a queue? Or just for extensions?
    What does the caller have to press, when he does not want his call to be recorded and DTMF 3 is enabled?
    Thanks for your support.
    Kind regards
    Karsten
