Recording of calls enabled but not recording
Discussion in '3CX Phone System - General' started by binary1, Jun 3, 2009.
  1. binary1
    May 4, 2009
    43
    Hi, can someone advise .... I have enabled call recording on the extensions but there is no recordings under the Data folder as such.
    Is there something else which I will need to enable?
  2. binary1
    May 4, 2009
    43
    Enabled PABX delivers audio as well but nothing.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Currently we are unaware of such a bug. Could you check in the following folders for any Recordings?
    For Versions 6 Check in C:\Program Files\3CX PhoneSystem\Data\Recording
    For V7 Check in Folders
    for Vista
    C:\ProgramData\3CX\Data\Recordings
    for XP
    C:\Documents and Settings\All Users\Application Data\3CX\Data\Recordings
    Make a fresh call from your Extension that you enabled Recordings and see what happens.
  4. binary1
    May 4, 2009
    43
    Thanks.
    Am using Windows 2003 server and it is in
    Found it thanks.
  5. MarcelvanKuilenburg
    Nov 6, 2009
    29
    for me the same problem. Stil no recording in the folder c:\documents and settings\application data\3cx\data\recordings. Do i need more adjustments but in global and with the extension. I restarted the services after getting a licence
  6. MarcelvanKuilenburg
    Nov 6, 2009
    29
    I restarted the 3cxphonesystem which hung on the comp. Therefore stopped the system manually and now everything, although call recording, is working. What a pleasant system 3cx is.
  7. LeonidasG
    Nov 19, 2008
    1,557
    118
    Yes it's very pleasant!
    Could you give us your system specs? O/S, Cassini / IIS? Any Service packs / Tried Installing Codecs...
  8. MarcelvanKuilenburg
    Nov 6, 2009
    29
    Leonidas, sorry for the confusion, also recording works after restarting. suprisingly 3cx. its still great.
