Recording on demand from within call - via dial code?
Discussion in '3CX Phone System - General' started by jtbool, Sep 2, 2017.
  1. jtbool
    Oct 13, 2016
    5
    Does anyone know if it's possible for a user (of a real phone, not softphone) to tell the PBX to record a call once it's in progress - for example by entering a dial code?
    We used FreePBX previously and dialling **1 or something like it would start recording from within the call. I can't seem to find a similar option or any mention of in-call recording around 3CX.
    Thanks!
    Jeff
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Not possible from a deskphone, eventually from 3CX client in CTI mode.
    From switchboard (in a 3CX softphone) you can also record calls on demand, if you have necessary rights.
    #2 sip.bg, Sep 2, 2017
    YiannisH_3CX likes this.
