recording sound file digital receptionist
Discussion in '3CX Phone System - General' started by jonnybluehat, Jun 30, 2011.
  1. jonnybluehat
    Feb 15, 2011
    8
    hello all
    having an issue with the sound quality of my recording played thru 3cx over the phone
    my recording is clean on my pc but sounds like its being broad casted thru a tin can over the system
    its in a wav file if it makes a difference
    thx
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    This is the issue when recording your own .wav files being played over the phone. Are you recording them through the 3CX Management console? or through an external program? if you are not using 3CX to make the audio are you using the correct settings? PCM .wav 16 Bit Mono 8Khz?
    Thanks,
    Nate
  3. jonnybluehat
    Feb 15, 2011
    8
    i do have all the same settings
    i recorded thru a logitec headset
    i didnt know it was possible to record from the console, can you tell me how
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    If you are using V10 anywhere there is a location to add a prompt there is a record button which will allow you to record a prompt from the handset.
