Solved Recording table incorrect?
Discussion in '3CX Phone System - General' started by complex1, May 8, 2017.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    788
    45
    I was checking call recording files and noticed something strange between the "Call Log" table and "Recordings" table.
    The "Call Log" table shows that John (201) was calling Hans (200) and what he did.
    But the "Recordings" table shows the opposite.
    At least the Source and Destination extensions are changed.
    Is the a bug or do I understand it wrong?
    This PBX (v15-SP5) is running on Debian (on-premise)
    Thank you.
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @complex1,
    We tried replicating this but no issue was found. If you restart your services, is it still the same?
  3. complex1
    Jan 25, 2010
    788
    45
    Hi @panayiotis_3CX,
    Thank you for your response.
    A restart of the complete box have solved the issue.
    Looks like Windows… a restart will fixed almost everything. ;)
