Recordings TimeStamp Settings??
Discussion in '3CX Phone System - General' started by SamuelKrawetz, Jan 25, 2016.
  1. SamuelKrawetz
    Jan 13, 2016
    17
    Hello
    I am curious why the time stamps of my filenames of recordings DO NOT match those in my local time.
    Recording filenames are 6 hours ahead of us.
    Is there anyway to fix this??
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,134
    211
    i get so few messages as if i am not in office, they call my cell. - I do not notice...
    timezone of server correct?
    user with incorrect timestamp in same timezone as server?
  3. SamuelKrawetz
    Jan 13, 2016
    17
    All time zones are in sync on our user computers and the server are exactly the same.
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    All time stamps are in UTC time.
  5. SamuelKrawetz
    Jan 13, 2016
    17
    So there is no way to change this?
  6. NickD_3CX
    Jun 2, 2014
    1,283
    68
    Unfortunately not.
  7. SamuelKrawetz
    Jan 13, 2016
    17
    That seems like a minor thing, but our calls get verified and the time and date are very important.
    I suppose I can have a script ran to rename the files but I still don't understand why they would show up in another time zone even though the time zones match up everywhere else. smh??
  8. NickD_3CX
    Jun 2, 2014
    1,283
    68
    A word of warning, if you change the file names of the recordings in the folder where they are located, then if you generate a report from the Management Console, the links will not work for the recording because it will be looking for the original fine name.
