Solved Recordings view permission
Discussion in '3CX Clients' started by imagemaster, Aug 15, 2017.
  1. imagemaster
    Jul 20, 2010
    46
    In v15.5 where do you give individual users the right to view recordings. It mentions this in the documentation but I can't seem to find it.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,334
    533
    Hello @imagemaster
    You will need to provide access for those users to the management console by enabling the option under extension settings / rights.
    You will need to enable allow downloads of call recordings
  3. imagemaster
    Jul 20, 2010
    46
    Thanks. I also found it under Phone Provision --> 3cx Client --> Access.
