Redirect calls to specific number
Discussion in '3CX Phone System - General' started by elcom1, May 14, 2013.
  1. elcom1
    Mar 6, 2013
    7
    Is there a way to redirect calls to a specific number? I mean not changing state of the user but specifying the number.
    If the user goes to work fom his place near to internal 100, something like *3*100 to redirect all call to internal 100 from his own internal. Changing state with *3 + state_number is too rigid, the user must have the opportunity to choose freely the internal to which redirect calls.
    I couldn't find how to do that, is it possible?
    Thank You
    10,868
    304
    Not using a star (dial) code.
    http://www.3cx.com/blog/extension-user-manual/dial-codes/
    But you can manage fall forwarding from MyPhone
    http://www.3cx.com/blog/extension-user-manual/forwarding-rules/
  3. elcom1
    Mar 6, 2013
    7
    ThankYou.
    This is not exactly what I was looking for but probably I need to change my and my customers approach to this task.
