Redirect to external number if not registered
Discussion in '3CX Phone System - General' started by alex2911, Mar 2, 2009.
  1. alex2911
    Mar 2, 2009
    17
    Hi all
    i made a rule for redirect all calls to an external number in case if the voip-phone isn't registered.
    So far so good. But the log say: "Call is terminated" after 2 tries to reach the phone.
    [​IMG]
    This is extremly bad because this is why i made following rule (sorry, in german)
    [​IMG]
    Hope, someone can help me.
  2. matictec
    matictec New Member
    Mar 31, 2008
    188
    what voip provider do you have?
    do you follow the outgoning rules for the redirect-target?
  3. alex2911
    Mar 2, 2009
    17
    i had for outgoing a rule to just allow from the internal ID.
    So: Solved
