Redirect to Management Console?
Sopock
Hi!
I think it would be good to use redirect when we enter http://localip:5000/ (without /management/MainForm.wgx part)
Code:
Server Error in '/' Application.
The resource cannot be found.
Requested URL: /
if this is a recommendation, then pot to the ideas forum.
In my opinion, this is somewhat of a security concern. I prefer the longer URL.
Nobody will guess this URL and try to hack in...
Redirect menu
This solution would apply only to local network. But now I wonder how to enable access to web console and add new test host:
:S
I would recommend being very careful about what is changed in the WebServer because 3CX uses that heavily for most of the functions it initiates, ideally not touch it at all. One slight mistake and most things will not work. The bad thing about this is that 3CX Support will also not fix it for you, they will instruct you to make a Full Backup (if you can get into the Management Console and that isn't broke), uninstall, re-install and go again.
Also I must let you know that Abyss is a bit 'picky' with what you change...
Getting Started - Admin
Ghisl1
Get 3CX - Absolutely Free!
3CX
