Redirect with SIP Provider?
Discussion in '3CX Phone System - General' started by SIPfun, Jul 15, 2008.
  1. SIPfun
    Jun 23, 2008
    56
    I've been testing the check boxes...
    What situation could I test for to see if my provider uses redirect?
    And how does it help me?
  2. francesco
    francesco New Member
    Jun 23, 2008
    102
    Can you please give me an example?
  3. SIPfun
    Jun 23, 2008
    56
    When I add a VOIP provider to 3CX, there is a checkbox for indicating that the provider supports redirect...
    What is redirect - and how can I test to see if it's supported with my carrier.
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    There're two checkboxes - Supports re-Invite, and Supports 'Replaces'.
    First tells PBX if it is allowed to renegotiate codecs for that endpoint. If not - it will bound it to media server as a call starts.
    Second can be used only with re-invites, so it is grayed out if re-invites are disbled. It is just optimization hint for attended transfer. You should untick it if you have problems with attended transfers that involve that endpoint.
  5. francesco
    Jun 23, 2008
    102
    i don't see ..redirect :?: :?: :?:
  6. Anonymous
    Anonymous Guest
    Francesco,
    Are you sure you are talking about redirect?
    What are you trying to do?
    Thanks,
