Solved Redirecting Incoming Calls to External Number
Discussion in '3CX Phone System - General' started by interactive9, Jan 9, 2017.
  1. interactive9
    Oct 26, 2015
    22
    Good morning, we have a situation where we have to redirect an incoming call to one of our DIDs in the UK (via ISDN on Patton gateway) back out over the ISDN to a standalone analogue line at our German office.
    I have setup a forward if unavailable on the extension and entered the remote office phone number.
    The call goes through but callers don't hear any ringing tone, it's just silent until one to two seconds after the user in Germany answers the phone, then audio works fine.
    Any help much appreciated.
    Lawrie
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @interactive9
    Without a capture this is very difficult to troubleshoot but try to enable PBX delivers audio on the Gateways settings to see if that makes any difference. Also make sure that Supports Re-invite and Support Replaces are enabled
  3. interactive9
    Oct 26, 2015
    22
    Hi YiannisH
    This "enable PBX delivers audio on the Gateways settings" appears to have resolved our issue.
    Thanks for your help.
  4. YiannisH_3CX
    May 10, 2016
    7,400
    535
    Glad to hear this worked and thank you for sharing
