Reduce Time Numbers Dialed Are Sent to PBX?
Discussion in '3CX Phone System - General' started by millennium2, Jun 27, 2014.
  1. millennium2
    Apr 8, 2011
    57
    How does one reduce the time Numbers Dialed are Sent to the PBX?
    I know outbound calls are sent by hitting the SEND key. However, if I pickup the phones Handset (or hit the Speaker phone button), I hear dial tone, then Dial a Number (WITHOUT hitting the SEND key), there is about a 5 second delay before the call is sent to the PBX.
    Is there a way to reduce this 5 second time delay?
    FYI, I am using a Yealink T38g phone. Thank you.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You can try to use a "reversed" procedure.
    1. enter the number you need to call
    2. pickup your Handset..
    or
    2. hit the Speaker phone button
    Works?
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    go into the phone's web interface and look for a setting called dial delay, inter-digit delay or the like and reduce it to a time more suitable. this will eliminate a manual intervention, but will likely result in dialing too soon in some cases.
