Redundant SIP Paths.
Discussion in '3CX Phone System - General' started by weaver4z, Apr 13, 2010.
  1. weaver4z
    Apr 13, 2010
    We have a customer that wants redundant SIP paths between 3CX and two Cisco Call Manager IP addresses, one primary and one secondary. Can 3CX do this?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Can you give more detailed request?
  3. weaver4z
    Apr 13, 2010
    I guess my first question is: "Can a 3CX system work with a Cisco Call Manager System". Imagine that Business has two buildings one old building that uses a "Cisco Call Manager" and a second building that uses a 3CX and we want to connect the phone systems together and then set up extensions between the two. Is it possible to connect the two systems and what would we use as the bridge between the two? a simple Ethernet with Sip or a T1->Gateway->3CX?
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi there,
    This is not a supported setup. And you can encounter many problems. Having said that you can take a look at this forum post below, but you would be far easier to have 2 bridged 3CX PBX's.
    http://www.3cx.com/forums/3cx-to-cme-6914.html
  5. weaver4z
    Apr 13, 2010
    What hardware between the two would you recommend? Just Ethernet?
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    3CX PBX supports any type of connection:
    1. Ethernet. 3CX is user. Cisco call manager is Voip provider
    2. Ethernet. 3CX is VoIP provider. Cisco is user.
    3. Ethernet. SIP trunk. It is the same as 1. and 2. but without SIP registration procedure
    4. wire + gateways. The wire and SIP gateway is mandatory on 3CX PBX side because we provide ONLY SIP interface.
    Independently of connection type, the problem is to configure CCM and 3CX PBX to understand each other. It is expected that it will be easy on 3CX PBX side.
