Redundant SIP with the same DID
Discussion in '3CX Phone System - General' started by wcoggins, Feb 1, 2017.
  1. wcoggins
    May 8, 2014
    17
    16
    I have searched through the forums and not seen a definite answer to this question.
    Our VOIP Provider has redundant ip's that we can connect to for the same DID. A call to the DID 111 222 3333 can come into the 3cx from xxx.itel.com OR yyy.itel.com. This is their method of load balancing and fail-over.
    I see that most of the major, world class providers use this topology.
    Can I put both ip's (or FQDN) into the "SIP server hostname or IP" field using comma separated values?
    [xxx.itel.com,yyy.itel.com]
    Does anyone know if the 3cx system simply authenticates the first one or both?
    Is there a better way to enter this into the VOIP Providers?
    Thank you for your help
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
