Reformatting outbound caller ID issue
Discussion in '3CX Phone System - General' started by exmoskl, Oct 3, 2014.
  1. exmoskl
    Oct 26, 2010
    7
    Evening
    I'm having a little issue but first, background so you know what I'm trying to achieve.
    We have a customer who wants to use 2 VOIP trunks and extentions have their own DDI/Caller ID numbers setup. The issue I face is that one trunk needs outbound caller ID format to be in standard UK format ie 01234123456 and the other can only accept international format outbound caller id ie 441234123456. So for one of the trunks, I need to setup outbound caller ID reformatting. I've confirmed both trunks accept outbound calls if I manually specify the correct caller ID format in the extension so know that the issue isn't with the trunk setup itself.
    I've tried setting up outbound caller ID reformatting - essentially with a rule that just replaces the 0 with 44 - the way I understood the 3CX page on reformatting was that I should be able to achieve this with the following:
    Source CID pattern: 0(.*)
    New Source CID pattern: 44\1
    This doesn't seem to work however - the number keeps being presented as per the extension caller ID. Do I need to set a specific outbound parameter as well or have I just got the reformatting rule parameters wrong? Outbound parameter at the moment is set to take the extension caller ID part and my understanding was that the reformatting rule would change this for the trunk that requires 44.
    Any and all help/guidance most appreciated.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there, this should have worked the way you have set the CID reformating, what provider are you using for this trunk?
  3. exmoskl
    Oct 26, 2010
    7
    Hi Pierre
    We have 2 trunks - Orbtalk and VoipUnlimited - both work fine if we manually set the extension CLID as per trunk requirements, its just the outbound reformatting of CLID to replace the 0 with 44 that doesn't seem to be applied.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    In fact the Outbound CID Reformating only applies to cases where inbound call comes into system then gets forwarded outside again. It won't work in cases where extension dials outbound number directly.
  5. exmoskl
    Oct 26, 2010
    7
    Really? You learn something new every day :)
    Thanks for the clarification Pierre
  6. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    You're welcome.
  7. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    This is possible if you set "Originator Caller-ID" as parameter in outbound parameters in outgoing provider settings for fields 'From: user part' and 'From: contact part'. This will send and modify correctly extension caller-id as required, as well as forwarded call coming from another trunk / provider. This is also the only way possible to form correct outbound caller-id for calls from bridged PBX.
