Regarding create 3CX phone system
Discussion in '3CX Phone System - General' started by jc160586, May 16, 2008.
  1. jc160586
    May 16, 2008
    IS it possible to create the 3CX phone system under the current PBX phone system which is using LG Nortel aria 300 PBX?
    we want to create a small 3CX phone system inside the current LG PBX phone network which means we want to use2 lines of the current extensions to connect the VoIP gateway of 3CX phone system. BUt we are not sure if this plan can be accomplished because according to 3CX system manual, VoIP gateway should be connected to PSTN lines. is it possible to connect our company's extension lines to 3CX phone system through VoIP Gateway??
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,970
    270
    You can do this with the use of an FXS gateway. Then it will use lines on your PBX....
  3. jc160586
    May 16, 2008
    Re: Regarding create 3CX phone system FXS Gateway?
    Thanks for your reply, could you recommand some types of FXS gateway for us? Thanks a lot
    by jc160586 on Fri May 16, 2008 2:17 am
  4. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    You can have a look at the VOIP Gateway Configuration Guides on 3CX Support Page (http://www.3cx.com/support/). I would recommend you a Patton product (http://www.patton.com), but you can still chose something else based on your needs.
    As for the configuration, I don't know how it needs to be made.
    This is an interesting subject, I was wondering how I could do it if we decide to keep an existing PBX.
