Regenerate welcome email
Discussion in '3CX Phone System - General' started by johnp@vvmicro.com, Jan 11, 2012.
  1. johnp@vvmicro.com
    Dec 30, 2011
    OK, I've looked around but I can't find how to regenerate the welcome email for an extension. Is there a way to do this?
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    51
    Goto Extensions, select the extension who you wish to send the welcome mail, click “Send welcome mail”
    eddiemcdeff likes this.
  3. JS_VNET
    Jun 18, 2014
    Dear 3cx Admins
    Is there a possibility to send the welcome email automated trough the API? As far as I know, the API is only for call control, so please correct me if i'm wrong.
    For example we would like to use it in a web application. Where registered users can send the config file to them self by clicking a button.
    Greez
    Joel
