Solved Register button disabled
Discussion in '3CX Phone System - General' started by La Sorgente, Jul 4, 2017.
  1. La Sorgente
    Jul 4, 2017
    Hello!
    I'm trying to register a new digital receptionist answer. But the button is disabled. Why? scrreeen.png
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,448
    541
    Hello @La Sorgente
    Can you please let me know what version of the PBX are you using?
    You can find the build number on the dashboard under the information column next to the licence.
  3. La Sorgente
    Jul 4, 2017
  4. YiannisH_3CX
    May 10, 2016
    7,448
    541
    Make sure that there are no invalid characters in the name of the prompt like a space in the end. Also does this happen to the specific IVR or does it happen also to a newly created one?
  5. La Sorgente
    Jul 4, 2017
    now it work... And i don't change anything.
  6. YiannisH_3CX
    May 10, 2016
    7,448
    541
    Glad to hear it is now working. Please let us know if you face this issue again
