Register Mediant 1000
Discussion in '3CX Phone System - General' started by sunero, Jul 7, 2008.
  1. sunero
    Jul 7, 2008
    11
    I have a problem register my AudioCodes Mediant 1000 and this is what I could find in the log :
    13:24:49.607|.\Authorization.cpp(106)|Critical0|Authorization|AuthMgr::eek:nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 192.168.11.126 tid=ac287722457 cseq=REGISTER contact=192.168.11.30 / 78 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
    Does anyone have a guide howto setup the Mediant 1000 or maybe just howto setup the "Proxy & Registration" page in the Mediant?
  2. sunero
    Jul 7, 2008
    11
    After a couple of hours i finally got it to work. I did a reset and followed the Audiocodes MP-114 setup guide.
