Register w/o password
Discussion in '3CX Phone System - General' started by xc99tour, Jan 30, 2007.
  1. xc99tour
    Jan 2, 2007
    37
    HI,
    I have an endpoint that attempts to register with an 3CX extension and even though the password is set to blank, I get a 407. Is this a bug or should there be some specific value in the password field to negate authication?
    Thanks,
    Larry
  2. xc99tour
    Jan 2, 2007
    37
    Fixed in Beta 5
  3. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    OK , thank you for your feedback.
