Registered, incoming no outgoing
Discussion in 'Android' started by jcarlilesiu, Nov 3, 2011.
  1. jcarlilesiu
    Nov 3, 2011
    Any help is appreciated.
    I am using 3CX with a virtualpbx account. I got it all setup, and the system is registering. I also set up the incoming call on the virtualpbx side, and when I call my VOIP number, the android rings. Great.
    However, outgoing calls fail. The screen shows on hook, but after dialing nothing happens. No sound, no ring tone. Nothing. Then after a short wait it returns to "on hook".
    When I call the voip number, the phone rings, and I can answer, but then dead again. Nothing.
    Any help?
  2. jcarlilesiu
    Nov 3, 2011
    Ok, update. It just worked on incoming call perfectly.
    Outgoing, still no joy.
    Says its calling the number, but never does, never makes a noise, and then just returns to "on hook".
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,480
    67
    Please check this
    http://www.3cx.com/forums/worked-once-then-nothing-afterwards-20947.html#p114070
