registers, rings on incoming call but cuts off when answerin
Discussion in 'Windows' started by vooose, May 6, 2008.
  1. vooose
    May 6, 2008
    I am using a SIP Server / VoIP provider (not 3CX Phone system)
    It almost works.
    It registers OK with my ISP, iinet (get 'On Hook' in status)
    It rings when someone calls, but goes dead when I answer.
    When calling I get a dial tone but then goes dead after I press the call button.
    Could it be a codec issue? Any help appreciated.
  2. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    hei vooose
    i don't understand your supposition. you register on your ITS, but you don't can talk with anybody. i think that this is a firewall problem. you have no traffic on a voip protocol UDP
  3. coelhopsi
    May 7, 2008
    84
    Audio problems usually mean there's some traffic being blocked by the firewall... try to double check its settings to see if all necessary ports are open...
  4. vooose
    May 6, 2008
    I have asked whether what I want to do is even possible, see question to 3cx support and response below. Please comment
    > If I want to use this application as a VOIP phone for home use and only one
    > user (me on my PC) do I have to install the server?
    and their response:
    Thanks for your interest in 3CX.
    The current VOIP Client we have do not support any voip providers or
    pbx, but only ours, therefore it won't work for you as a standalone phone.
    In the near future it will work as a standalone phone.
  5. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i think that 3CX can do this. why not?? you have to take a look on Shore tel, Gismo... And not at least at Skype. i think that is very good if they make the 3CX VoIP client also interoperate with another sip providers.
  6. meshad
    Aug 5, 2009
    41
    ur caling SIP to SIP? or GSM or PSTN to SIP?
