registrar smeshaStrar it's all too much
Discussion in '3CX Phone System - General' started by Linux32, Feb 27, 2008.
  1. Linux32
    Feb 27, 2008
    Everybody gather round....
    I have a Cisco(sip)model 7905 phone that goes on to our network (netgear) then travels to our
    VegaStream(50 6x4 telephony\H323\sip unit) then to the Sonicwall. In the 3cx phone system server it shows my phone calling extension 114 (I am extension 105) and then the lights turn yellow until someone picks up.
    That part was easy...to take it to the next level we work with a CRM program called GoldMine.
    The version is 8.02 and has a sip \softphone setup that I cannot get to work. The 3CX see's the phone extension when I use the softphone but does not know where to go. I am not sure what to do with the settings any more:
    sip server 192.168.1.xxx
    SIP server port: 5060
    Register with registrar: 192.168.1.xxx (is this correct...the number matches the phone)
    Registrar port:5060
    username:105
    password: 1234
    Local SIP:5060
    Access outside line: 99
    The 3cx allows me to call internally but to test it to go out to the real world is another thing. i have had 4 companies look at this and thay are all stumped. I am trying to master this artform called SIP so if anyone has anything to give please send it mt way
