Registration after loss of Network
Discussion in 'Windows' started by miniwi, Jul 11, 2011.
  1. miniwi
    Jul 11, 2011
    Hi there,
    I use 3cx on my phone and notebook. Every time the network connection is lost, 3cx does not re-registers again. Solution: I have to open the accounts, press ok and 3cx will reconnect. How can I prevent the status no connection or better allow an automatic reconnect after Standyby of the computer, WLAN cutoff a.s.o.
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    Try reducing the registration period on your phone.
    On 3CX server you can modify the following parameters (in Settings | Advanced | Custom parameters), related to the problem:
    'SIPPINGPERIOD' and 'EXPIRATIONGRACEPERIOD' (http://www.3cx.com/blog/docs/3cx-phone-system-parameters-table/).
    Regards
