Registration at Twilio has failed
Discussion in '3CX Phone System - General' started by Andrew Flatt, Mar 6, 2018.
  1. Andrew Flatt
    Mar 6, 2018
    3CX hosted in Google taking advantage of the year free licence.
    Twilio setup for their SIP Trunk offering.
    Able to receive calls but not make them. Trunk is not registering correctly.
    Logs show:
    Registration at Twilio has failed. Destination (sip:twillo@magpie.pstn.ie1.twilio.com:5060) is not reachable, DNS error resolving FQDN, or service is not available.
    I am able to ping the fqdn successfully from the terminal.
    I see another user with the same error and some redit detail around an issue between Google and AWS (where Twilio host their sip trunks).
    Does anyone know how to get this working?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
  3. Andrew Flatt
    Mar 6, 2018
    Confirmed I have followed this guide.
    When i ping the SIP provider from the 3CX console it resolves correctly. However the 3CX shows it cant be reached???
    There appears to be others experiencing the issue when Twilio is used especially when the 3CX is hosted in Googles cloud platform?
    Inbound voice is working correctly.
  4. YiannisH_3CX
    May 10, 2016
    4,443
    282
    Can you try to not use the localised termination URI (magpie.pstn.ie1.twilio.com) and use the termination URI you chose + pstn.twilio.com as it is shown in the documentation and see if that works? Yours should be magpie.pstn.twilio.com. I have tested a Twilio account on Google cloud and it is working for both inbound and outbound calls.
  5. YiannisH_3CX
    May 10, 2016
    4,443
    282
    Also make sure that your public IP has not changed since you created the trunk and it is set correctly set in the IP access control list inside Twilio's console. The username and password from the credentials lists should also be used in the management console although the trunk is IP based.
  6. Andrew Flatt
    Mar 6, 2018
    I have tried changing the URI as suggested - no difference - I have also tried IP addresses rather than FQDN - no difference.
    I have tried username and pw only, IP only, IP and username - no difference.
  7. StefanW
    Jun 2, 2009
    1,199
    79
    what config is in resolver.conf?
  8. Andrew Flatt
    Mar 6, 2018
    Sorry I can't see (or find any guides) how to get into the underlying file system when i'm using your hosted service?
