Registration error: 408 - Request Timeout
Discussion in '3CX Phone System - General' started by mbais, Dec 9, 2007.
  1. mbais
    Nov 16, 2007
    I can't register an x-lite phone from outside.
    From inside the firewall check fails with the following errors:
    1 9000 Error (4) Global address (returned by STUN) is not accessible from outside. This issue can be generated only if a STUN server is defined for checking. addrFromSTUN = 82.93.164.152:57376
    2 9000 Error (6) Different NAT translation for different requests (to STUN and to Firewall Checker Agent). This situation can occur if there is something wrong with NAT translation or a symmetric NAT is used. addrFromAgent = 82.93.164.152:57381
    3 9000 Warning (8) Local port is not blocked from outside. STUN server has returned global port different from the local one, but the local port is also accessible from outside.
    4 9000 Warning (10) Port number has been changed during NAT translation. externalAddress = 82.93.164.152:57376
    My firewall reports that all is well:
    {Administrator}[systemlog]=>show
    <84> Dec 9 15:36:32 FIREWALL rule (1 of 3) : Protocol: UDP Src ip:
    87.230.29.162 Src port: 4200 Dst ip: 192.168.1.78 Dst port: 9000 Chain: forward_host_service Rule Id: 46 Action: accept
    <84> Dec 9 15:37:15 FIREWALL rule (1 of 1) : Protocol: UDP Src ip: 213.201.133.242 Src port: 2281 Dst ip: 192.168.1.78 Dst port: 5060 Chain: forward_host_service Rule Id: 45 Action: accept
    -> the first entry is the firewall check;
    -> the second entry is my x-lite phone connecting to the 3cx server
    The x-lite phone seems to be registered on the server, but the extension is unaware (408 error).
    What is going wrong with the STUN-test on the server?
    Thanks.
