registration error
Discussion in '3CX Phone System - General' started by levbe, May 14, 2008.
  1. levbe
    Apr 27, 2008
    33
    Maybe someone can explain the following line :
    [CM504005]: Registration failed for: 10001@IPNESS; Cause: 503 Service Unavailable; warning: ; internal
    I try to register with a provinder witch does not indicate any IP address, ony ipness.net port 6060, login and pwd.
    Registration is working fine directly with a SIP Phone (SPA962) and 3CX works also fine with another VOIP provider.
    The provider's support is not able to give any answer, so... (yes, i should change in this case, but i want to find out what's wrong before)
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Simple ping of ipness.net gives me request timeout error. What else could be said?
  3. coelhopsi
    May 7, 2008
    84
    Hey archie, don't forget that ping reply could be being blocked... Try to ping sip.inphonex.com, for example. Times out, but the host exists! :)
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    Ping inphonex.com goes OK
  5. coelhopsi
    May 7, 2008
    84
    http://ipness.com works OK as well... this means they're blocking ping replies.
  6. datu503
    May 17, 2008
    14
    did you try to register using their ip address, 82.146.119.47
    it should work.
  7. archie
    3CX Support
    Aug 18, 2006
    1,299
    I was given ipness.net and it neither ping nor work as http.
    Actually, I was not talking about ping itself. I was interested if domain name could be resolved. In case of ipness.com it is resolved, in case of ipness.net - it doesn't.
  8. coelhopsi
    May 7, 2008
    84
    Hey archie... sorry, don't know why I had the .com in mind!
    But strange... both ipness.net and ipness.com resolve for me:
    ipness.com: 82.146.119.47
    ipness.net: 82.146.119.38
  9. levbe
    Apr 27, 2008
    33
    Thanks for all, problem solved now.
    I've tried to register with their IP, without success.
    Some weeks after, IPNess replied to my question and they modified my login (from a username like "user" to "322335xxxx", my phone number in fact) and since registration is OK.
