Registration expiration for extensions*Discussion
Discussion in '3CX Phone System - General' started by vsefcik, Aug 26, 2010.
  1. vsefcik
    Nov 18, 2009
    19
    I have a mixture of SIP phones that I'm using as 3CX extensions. All of them seem to come from the factory with the Registration Expiration set to 3600 (3600 seconds, or 60 minutes). I want to shorten the period, which I know how to do on each phone. However, I have noticed that when an extension registers and specifies that the expiration period should be 3600 seconds, 3CX responds with a SIP 200 OK message that changes the expiration period to 1800 seconds. If I change the extension expiration period to something short (like 600 seconds), 3CX responds in the SIP 200 OK message with an expiration period of 600 seconds. So, is there some configuration parameter in 3CX (version 9) that specifies a maximum extension registration period of 1800 seconds?
    10,570
    247
    Re: Registration expiration for extensions
    The 30 minute expiry time seems to be the 3CX default. This has come up in the past and I don't recall seeing anything about being able to change that.
  3. vsefcik
    Nov 18, 2009
    19
    Thanks, leejor. I tried searching the forums for this topic, but couldn't find the answer. I'll just go with a setting of 600 seconds.
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    There's custom parameter "MAXEXPIRATION", it is set to 1800 by default. You can change it.
