registration expired ???
Discussion in '3CX Phone System - General' started by Tugi2o, Sep 6, 2007.
  1. Tugi2o
    Feb 20, 2007
    61
    i have a little problem:
    First i register all the lines at the voip provider...some days/weeks later all lines are not unregistered?
    LOG:
    ServRegs:checkExpiration [CM13000] Registration for sip: xxx@xxx.xxx.x.x. has expired.
    This happens with all lines.
    Only when i register each line manually they are registered.
    The settings are: Time between registration attempts: 360 (seconds)???
    So 3CX Software should do it automatically. Or is there an other problem???
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Expiration is checked only for those devices which are registering at PBX, not at VoIP provider. So, when you're registering your VoIP line at VoIP provider - it can not get expired. It will refresh registration before it expires.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    type of Voip provider
    Which Voip provider are you using for information purposes?
