REGISTRATION EXPIRES
Discussion in '3CX Phone System - General' started by kirimis, Nov 22, 2007.
  1. kirimis
    Oct 16, 2007
    43
    Can somebody tell me why am getting the message "Registration for sip:122@xxx.xxx.xxx.xx has expired" for some of my extensions and how can i eliminate that?
  2. jb
    jb
    Nov 22, 2007
    5
    What are your extensions? Are they software VoIP phones or hardware devices?
  3. kirimis
    Oct 16, 2007
    43
    REGISRTRATION EXPIRES
    hardware voip phones
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    For version 3 you may try to tweak 3CXPhoneSystem.ini file:
    [General]
    ExpirationGracePeriod = 10
    and restart service. If it doesn't help - use bigger value (it''s in seconds).
    If it still doesn't help - than problem is in the phone - it doesn't refresh registration in time. What is phone model by the way?
  5. kirimis
    Oct 16, 2007
    43
    REG EXPIRES
    Thanks you for your qiuck response. I wll try that
    The phone is from company onevoip and it is called siptalk i dont think that you even heard it again.
