Registration failed on Siemens Gigaset A580IP
Discussion in '3CX Phone System - General' started by Raf Wenger, Oct 13, 2010.
  1. Raf Wenger
    Apr 5, 2010
    23
    I'm having trouble registering this new Gigaset A580IP with the 3CX Phone System (v9 SP2).
    I can successfully register a dozen handsets on the same 3CX server (Linksys, YeaLink, Snom), so I guess my 3Cx phone system is configured properly.
    I can however register the Gigaset A580IP successfully with a VOIP provider, but not with my internal 3CX PBX.
    At one stage, while the extension status was showing "Not registered", I was able to make an internal call from the A580IP but could not receive call on it (it went straight to voicemail).
    I've checked the 3CX system logs and only found the following line (ext 833 is the A580IP, 192.168.1.99 is my 3CX server)
    15:30:29.018 [CM503016]: Call(6): Attempt to reach <sip:833@192.168.1.99> failed. Reason: Not Registered
    I've read on this forums that other users managed to register that phone successfully. Any help would be greatly appreciated.
    By the way, I am using the latest firmware available for the A580IP (022230000000 / 047.00)
    Thanks!
    Raf
  2. Andy8912
    Apr 30, 2011
    5
    Hi All.
    Anyone with a working setup for the A580ip phone, could you let me have the settings, I can make internal calls but recieve Voip Status 404 message when trying to make external calls.
  3. Raf Wenger
    Apr 5, 2010
    23
    Hi Andy,
    I had that problem too...
    Make sure the RTP ports of the A580IP and the 3CX PBX are identical.
    On the A580IP:
    Telephony > Advanced Settings > RTP Port
    On 3CX PBX:
    Settings > Network > Port > Ports to use for internal leg of Voip provider calls
    Hope this helps.
    Cheers
    Raf
  4. Andy8912
    Apr 30, 2011
    5
    Hi Raf thanks for the reply,
    I made the changes but still have the same issue.. I set the A580IP to the same ports as the 3cx: 7000-7499
    could i trouble you for your working setup.?
    Cheers
  5. Raf Wenger
    Apr 5, 2010
    23
    No worries.
    Can't seem to attach file to this post, so you can get it from my public dropbox folder:
    http://dl.dropbox.com/u/4575313/Gigaset%20A580IP%20config.pdf
    Cheers
    Raf
  6. akito
    Sep 9, 2009
    11
    Hi there. I've had a similar issue with my 470 IP together with the V9 of 3CX. Couldn't find any solution to these problems.
    Then recently I've changed to V10 RC and all issues were resolved.
  7. Andy8912
    Apr 30, 2011
    5
    Great Job Raf,
    my setup was the same but for the dtmf send settings, under Telephony-Advanced
    Much appreciated, All working now.
  8. acwild
    Dec 4, 2009
    Please can You help me . I've the same problem with the same telephone . Ca n anyone help me. I've controlled the rtp port and are the same. Or anyone like Raf wenger can send me a copy of nice configuration? :S
  9. leejor
    10,872
    304
    It's always better to begin your own thread , rather than re-opening one from a number of years ago.
    I'm using several C610A-IP bases, so I'm not sure if the menu set-up is exactly the same as on your model, it is probably similar though. As I recall, I left most of the settings in the Advanced VoIP settings in default. If you want to list what setting you have, I can compare it to mine.
    What issues are you actually having with the phones?
  10. acwild
    Dec 4, 2009
    Thanks Leejors. Here is my configuration
  11. leejor
    10,872
    304
    On the Settings/Connections page. I have the server IP in the Domain setting as well. So it is in there 3 times, on that page. You do not have to enable STUN as the phone appears to be located on the same LAN as the server. I would set the Registration refresh time at something just under 1800 seconds (30 minutes), say 1700. 60 seconds is far too often.
    On the Settings/Advanced VoIP settings page, I have DTMF set to Auto (If your current settings work, then don't change it)
    I have ..Use the R key for transfer, set to yes.
    You can define the choice of target address in the SIP protocol.
    Find target addr. automatically: Yes No
    Derive target address:
    from the SIP URL
    from the SIP contact header
    I'm not certain on the wording or your menu, my selections (above) are in bold, they may or may not work for you.
    The remaining menu is as follows:
    Listen ports for VoIP connections
    Use random ports: Yes No
    SIP port: - 5060- (5076) greyed out
    RTP port: - 5004-5020
    Music on hold
    Yes No
  12. acwild
    Dec 4, 2009
    Thank you very much . Resolved the problem was that in domain i must insert again the ip address . When I insert in it registered normaly.
    :D
  13. leejor
    10,872
    304
    I sort of figured that that was the problem. It took me a few minutes to realise that the server IP had to go in three places.
    The phone was designed for use with external VoIP providers and offers the needed "settings flexibility" for that.
