Registration failed Once on two
Discussion in '3CX Phone System - General' started by yam.300, Mar 11, 2008.
  1. yam.300
    Feb 25, 2008
    Once on two the registration failed, with the version 3 of 3cx this problem not appears. With a new install (xp and 3cx) the problem persist.
    Thanks for your help.
    Provider : Free
    VOip provider : Keyyo
    OS : XP without firewall
    DMZ on 3CX server
    Ports test => ok
    Phone : Linksys SPA941
    3cx version : 3CX5.1.4128.0
    14:59:29.140 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10000@keyyo
    14:59:28.031 ClientRegs::Register [CM504003]: Sent registration request for 10000@keyyo
    14:58:27.750 ClientRegs::eek:nFailure [CM504007]: Next attempt to register 10000@keyyo is scheduled in 1 minute
    14:58:27.750 ClientRegs::eek:nFailure [CM504005]: Registration failed for: 10000@keyyo; Cause: 407 Proxy Authentication Required; warning: Noisy feedback tells: pid=19899 req_src_ip=88.171.*.* req_src_port=5060 in_uri=sip:keyyo.net:5060 out_uri=sip:keyyo.net:5060 via_cnt==1; from IP:83.136.161.72:5060
    14:58:27.109 ClientRegs::Register [CM504003]: Sent registration request for 10000@keyyo
    14:57:26.828 ClientRegs::eek:nFailure [CM504007]: Next attempt to register 10000@keyyo is scheduled in 1 minute
    14:57:26.828 ClientRegs::eek:nFailure [CM504005]: Registration failed for: 10000@keyyo; Cause: 407 Proxy Authentication Required; warning: Noisy feedback tells: pid=4957 req_src_ip=88.171.*.* req_src_port=5060 in_uri=sip:keyyo.net:5060 out_uri=sip:keyyo.net:5060 via_cnt==1; from IP:83.136.162.72:5060
    or sometime :
    13:11:26.906 Call::RouteFailed [CM503014]: Call(52): Attempt to reach [sip:0175439500@192.168.0.120] failed. Reason: Reason Unknown
    13:11:26.890 CallLeg::eek:nFailure [CM503003]: Call(52): Call to sip:0175439500@keyyo.net:5060 has failed; Cause: 400 Complete RFC 3261 loose routing support is required to used this service; warning: Noisy feedback tells: pid=19892 req_src_ip=88.171.*.* req_src_port=5060 in_uri=sip:0175439500@keyyo.net:5060 out_uri=sip:0175439500@keyyo.net:5060 via_cnt==1; from IP:83.136.161.72:5060
    13:11:26.187 CallLeg::eek:nFailure [CM503003]: Call(52): Call to sip:0175439500@keyyo.net:5060 has failed; Cause: 407 Proxy Authentication Required; warning: Noisy feedback tells: pid=28160 req_src_ip=88.171.*.* req_src_port=5060 in_uri=sip:0175439500@keyyo.net:5060 out_uri=sip:0175439500@keyyo.net:5060 via_cnt==1; from IP:83.136.161.75:5060
