Registration Fails but all still functions?
Discussion in '3CX Phone System - General' started by dynamic, Oct 22, 2014.
  1. dynamic
    Oct 10, 2014
    16
    I'm getting the below error in my logs ever minute. When I look at the trunk status it says it's not registered. But outbound and inbound calls still work. Any ideas?
    Registration failed for: Lc:10001(@2Talk[<sip:mad:plus.2talk.com:5060>]); Cause: Cause: 403 Forbidden (Bad auth)/REGISTER from 27.111.12.66:5060
    10,371
    230
    Your provider should be able to tell you why it says "forbidden".
    In many cases, outgoing calls will work even without being registered, incoming usually won't. Obviously your provider knows your location (IP) to be able to send you calls. They should also be able to tell you what they see as being incorrect.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,977
    183
    It is possible your provider uses IP Based Reg and not credential based. not sure exactly. I have not used them. Best to talk to their support team. Might also try registering just 1 phone and take 3cx out of the equation temporarily.
