registration of an unsupported VoIP provider
Discussion in '3CX Phone System - General' started by gerlow, May 12, 2009.
  1. gerlow
    Apr 6, 2009
    8
    I am setting up a VoIP provider, it is registrered and I call that number. But when I hang up, and try to call again I can't connect/call. But after "Refresh registration" of that VoIP provider it works? It seems like the "trunk" hangs after a call??
    Somebody any idea?
    Thx!!
    /Staffan
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Re: registration of a VoIP provider hangs after call
    What is your provider?
    is it supported from 3CX?
  3. leejor
    11,277
    360
    What do the logs in the 3CX show, during and after you've hung up?
